First, I am deeply grateful to you for your very solicitous assistance - the norm in help fora like this is to dismiss less technically competent folk out of hand. In actuality I am not quite as lost as I may have implied - I am entirely comfortable rooting around in file explorer.
That said, I fear we have a slightly more difficult problem here: the FOL067AB.PMM file is well short of the 2 GB limit. It is indeed large, but is actually only 1,320,095 KB at present. (For what it is worth, FOL067AB.PMI, which I suspect is the index for this particular file, is 599 KB. Not likely to be relevant, but there it is, in case.)
I have no problem archiving the existing Main folder and creating a new one if that is easier, (rather than trying to fix the existing one - the folder functions perfectly well. It is just that I cannot delete anything without throwing the index in a tizzy.) Alternatively if there is some kind of rebuild of the existing Main folder which will fix it, I am equally game to go that route - whichever you feel is easier.
And, again, thank you so much for your generous assistance.
