[quote user="MikeGlen"]
My organisation uses Pegasus and Mercury on a mixed Windows/Netware network.
When Pegasus loads it appears to map the first available drive letter (in our case drive F) to volume SYS.
Our machines already have two local drives (C and D) and I need to keep drives E and F free for removable drives (e.g. usb).
1. Is it possible to prevent Pegasus from mapping a drive (drive G is already mapped to SYS in the login script)?
-- or --
2. Can Pegasus be forced to use a different drive?
I would appreciate any suggestions/insight.
Well I was pretty sure there is an option, but both Thomas an I cannot find it documented anywhere, but here it is from the top of my head.
You can use SET PMDRIVE=<driveletter> to force Pegasus Mail to run from that drive. Of course mappings should be ok. You can set is as a dos environment variable in whatever way (login script, windows configuration etc).
[quote user="MikeGlen"]<p>My organisation uses Pegasus and Mercury on a mixed Windows/Netware network.</p>
<p>When Pegasus loads it appears to map the first available drive letter (in our case drive F)&nbsp;to volume SYS.</p>
<p>Our machines already have two local drives (C and D) and&nbsp;I need to keep drives E and F free for removable drives (e.g. usb).</p>
<p>1. Is it possible to prevent Pegasus from mapping a drive (drive G is already mapped to SYS in the login script)?</p>
<p>-- or --&nbsp;</p>
<p>2.&nbsp;Can Pegasus be forced to use a different drive?</p>
<p>I would appreciate any suggestions/insight. [I]</p><p>[/quote]</p><p>Well I was pretty sure there is an option, but both Thomas an I cannot find it documented anywhere, but here it is from the top of my head.</p><p>You can use SET PMDRIVE=&lt;driveletter&gt; to force Pegasus Mail to run from that drive. Of course mappings should be ok. You can set is as a dos environment variable in whatever way (login script, windows configuration etc).</p><p>
Han van den Bogaerde - support@vandenbogaerde.net
Member of Pegasus Mail Support Group.
My own Pegasus Mail related web information:
http://www.vandenbogaerde.net/pegasusmail/
