IERenderer error when using preview pane for the first time in session
Dear Helpers
Since a while - already before I installed the newest version of IERenderer (2.6.6.5) I have this strange happening, when I want to use the preview pane (for the first time in a Pegasus session):
  • when touching the scroll bar
  • when touching the text
The message text always is the same.
Any ideas for t he reason - or even remedy?
Dear Helpers Since a while - already before I installed the newest version of IERenderer (2.6.6.5) I have this strange happening, when I want to use the preview pane (for the first time in a Pegasus session): - when touching the scroll bar - when touching the text [Pegasus-IERenderer.png](https://daube.ch/zz_tests/Pegasus-IERenderer.png) The message text always is the same. Any ideas for t he reason - or even remedy?
Most likely a focus issue, I may already have fixed this in my current development version but I'm not sure since it only occured on any of my system's very randomly and I could never trace it back to any particular screnario like you can. Other's have reported it as well.
I'm currently reluctant to release my update since it contains a major rewrite of the image download implementation due to the need for applying safer connection handling and PM 4.81 being already in pre-release testing for providing the new GMail authentication algorithm which I don't want to cause another delay for.
If you would be willing to get an IER test version please let me know (which Windows version are you using?).
[quote="pid:55070, uid:3311"]Any ideas for t he reason - or even remedy?[/quote] Most likely a focus issue, I may already have fixed this in my current development version but I'm not sure since it only occured on any of my system's very randomly and I could never trace it back to any particular screnario like you can. Other's have reported it as well. I'm currently reluctant to release my update since it contains a major rewrite of the image download implementation due to the need for applying safer connection handling and PM 4.81 being already in pre-release testing for providing the new GMail authentication algorithm which I don't want to cause another delay for. If you would be willing to get an IER test version please let me know (which Windows version are you using?).
Thank You Michael!
Since this is only an annoyance (as I know now), no hurry needed to fix...
Thank You Michael! Since this is only an annoyance (as I know now), no hurry needed to fix...
