I have a user who sent an email and when it was received it appeared differently (with #&160 showing in all spaces?). I believe it was sent with the Rich Text option checked, but except for spaces around plain text, there was no other formatting. Would that cause the text to appear differently when received? I have copied portions of text from both the sent version and the received version below.
Message format when sent:
Here's the figures for the paydowns for Tuesday. So far fairly quite which is good. Thanks, see you on Friday.
pool # principal amt amrt amt
254239 48.18 3,040.89
Message format when received:
> pool
60;
254239
0;
48.18
> 3,040.89
<P>I have a user who sent an email and when it was received it appeared differently (with #&amp;160 showing in all spaces?).&nbsp; I believe it was sent with the Rich Text option checked, but except for spaces around plain text, there was no other formatting.&nbsp; Would that&nbsp;cause the text to appear differently when received?&nbsp;&nbsp; I have copied portions of text from both the sent version and the received version below.</P>
<P><STRONG><U>Message format when sent:</U></STRONG></P>
<P>Here's the figures for the paydowns for Tuesday. So far fairly quite which is good. Thanks, see you on Friday. </P>
<DIV class=c2><SPAN class=c1>
</SPAN></DIV>
<DIV class=c2><SPAN class=c1>pool # principal amt amrt amt</SPAN> </DIV>
</SPAN></DIV>
<DIV class=c2><SPAN class=c1>254239 48.18 3,040.89</SPAN> </DIV>
</SPAN></DIV>
<DIV class=c2><SPAN class=c1><STRONG><U>Message format when received:</U></STRONG></SPAN></DIV>
<DIV class=c2><SPAN class=c1></SPAN>&nbsp;</DIV>
<DIV class=c2><SPAN class=c1>Here's the figures for the paydowns for Tuesday.&amp;#160; So far</DIV>
<DIV class=c2>
<P align=left>&gt; fairly quite which is good.&amp;#160; Thanks, see you on Friday.</P>
<P align=left>&gt; pool</P>
<P align=left>&gt;</P>
<P align=left>#&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#1</P>
<P align=left>60;</P>
<P align=left>&gt; principal amt&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160; amrt amt</P>
<P align=left>&gt; </P>
<P align=left>254239&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#16</P>
<P align=left>0;&amp;#160;&amp;#160;</P>
<P align=left>48.18&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160;&amp;#160</P>
<P align=left>;</P>
<P align=left>&gt; 3,040.89</P></SPAN></DIV>
