Hello All
Just seen the light and for once it wasn't a train coming. For some reason although I am able to access my network drive (F: and up), when running the PMail NDS config PMail said it was unable to access the mailbox. When I navigated to the SYS/ in explorer, explorer said I had insufficient rights. The fix was to disconnect drive F: in the NW client and remap the drive using the XP drive mapping tool ( ie; right click and map - NOT the Netware mapping). Hope this helps someone else.
Many thanks for your replies
TTFN
<P>Hello All</P>
<P>Just seen the light and for once it wasn't a train coming. For some reason although I am able to access my network drive (F: and up), when running the PMail NDS config PMail said it was unable to access the mailbox.&nbsp; When I navigated to the SYS/ in explorer, explorer said I had insufficient rights.&nbsp; The fix was to disconnect drive F: in the NW client and remap the drive using the XP drive mapping tool ( ie; right click and map - NOT the Netware mapping).&nbsp; Hope this helps someone else.</P>
<P>Many thanks for your replies</P>
<P>TTFN&nbsp;</P>
<P mce_keep="true">&nbsp;</P>
