Help - Attaching jpegs
[quote user="shubunkin"]
Please forgive me if this has been covered - I searched the site but couldn't find a post addressing this.  When trying to send jpeg photos as attachments, I get an error that appears to be because of size.  This happens even when I use a zip file as the attachment.  However, I can receive e-mails (that have numerous, unzipped jpeg files, or a large zip file) and view them in Pegasus.  Is there a default setting somewhere that would allow me to send out e-mails with larger attachments?  The error message is:
   552 size limit exceeded
There is no size limit in Pegasus Mail.  Almost all ISPs though set a limit on size of a message received by their SMTP hosts. If you do a session log there will be a section showing their size limit.  This is a sample of what I see with GMail in a session log,
11:03:19.985 >> 0040 220 smtp.gmail.com ESMTP 35sm218440wra\0D\0A
11:03:19.000 << 0020 EHLO [192.168.1.2]\0D\0A
11:03:19.079 >> 0036 250-smtp.gmail.com at your service\0D\0A
11:03:19.079 >> 0019 250-SIZE 20971520\0D\0A
11:03:19.079 >> 0014 250-8BITMIME\0D\0A
11:03:19.079 >> 0022 250-AUTH LOGIN PLAIN\0D\0A
11:03:19.079 >> 0025 250 ENHANCEDSTATUSCODES\0D\0A
and it says they have size limit of 20, 971, 520 bytes.  Others are much smaller.
[quote user=&quot;shubunkin&quot;]&lt;p&gt;Please forgive me if this has been covered - I searched the site but couldn&#039;t find a post addressing this.&amp;nbsp; When trying to send jpeg photos as attachments, I get an error that appears to be because of size.&amp;nbsp; This happens even when I use a zip file as the attachment.&amp;nbsp; However, I can receive e-mails (that have numerous, unzipped jpeg files, or a large zip file) and view them in Pegasus.&amp;nbsp; Is there a default setting somewhere that would allow me to send out e-mails with larger attachments?&amp;nbsp; The error message is:&lt;/p&gt; &lt;p&gt;Delivery has failed on the enclosed message for the following reasons reported either by the mail delivery system on the mail relay host or by the local TCP/IP transport module: &amp;nbsp;&amp;nbsp; 552 size limit exceeded&lt;/p&gt;&lt;p&gt;[/quote]&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;There is no size limit in Pegasus Mail.&amp;nbsp; Almost all ISPs though set a limit on size of a message received by their SMTP hosts. If you do a session log there will be a section showing their size limit.&amp;nbsp; This is a sample of what I see with GMail in a session log, &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;11:03:19.985 &amp;gt;&amp;gt; 0040 220 smtp.gmail.com ESMTP 35sm218440wra\0D\0A 11:03:19.000 &amp;lt;&amp;lt; 0020 EHLO [192.168.1.2]\0D\0A 11:03:19.079 &amp;gt;&amp;gt; 0036 250-smtp.gmail.com at your service\0D\0A 11:03:19.079 &amp;gt;&amp;gt; 0019 250-SIZE 20971520\0D\0A 11:03:19.079 &amp;gt;&amp;gt; 0014 250-8BITMIME\0D\0A 11:03:19.079 &amp;gt;&amp;gt; 0022 250-AUTH LOGIN PLAIN\0D\0A 11:03:19.079 &amp;gt;&amp;gt; 0025 250 ENHANCEDSTATUSCODES\0D\0A&lt;/p&gt;&lt;p&gt;and it says they have size limit of 20, 971, 520 bytes.&amp;nbsp; Others are much smaller. &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp; &amp;nbsp;&lt;/p&gt;
&lt;P&gt;Please forgive me if this has been covered - I searched the site but couldn&#039;t find a post addressing this.&amp;nbsp; When trying to send jpeg photos as attachments, I get an error that appears to be because of size.&amp;nbsp; This happens even when I use a zip file as the attachment.&amp;nbsp; However, I can receive e-mails (that have numerous, unzipped jpeg files, or a large zip file) and view them in Pegasus.&amp;nbsp; Is there a default setting somewhere that would allow me to send out e-mails with larger attachments?&amp;nbsp; The error message is:&lt;/P&gt; &lt;P&gt;Delivery has failed on the enclosed message for the following reasons reported either by the mail delivery system on the mail relay host or by the local TCP/IP transport module: &amp;nbsp;&amp;nbsp; 552 size limit exceeded&lt;/P&gt;
