Mercury Core Process Module
Yes. Moving a message from the queue effectively kills it.
-- David --
Yes. Moving a message from the queue effectively kills it. Cheers! -- David --
What is the difference between these 2 entries and what triggers each of them ??
* killed by filtering rule.
* killed by global spam processor.
Thanks.
<P>What is the difference between these 2 entries and what triggers each of them ??</P> <P>* killed by filtering rule. * killed by global spam processor.</P> <P>Thanks. </P>
[quote user="tomt"]
"Killed by filtering rule" means that the message was deleted by a Delete or Move action in a global filtering rule.
"Killed by global spam processor" means that the message was deleted as the result of a classification as spam from either SpamHalter or Content Control.
-- David --
[quote user="tomt"]<p>What is the difference between these 2 entries and what triggers each of them ??</p> <p>* killed by filtering rule. * killed by global spam processor.</p> [/quote] "Killed by filtering rule" means that the message was deleted by a Delete or Move action in a global filtering rule. "Killed by global spam processor" means that the message was deleted as the result of a classification as spam from either SpamHalter or Content Control. Cheers! -- David --
Thanks David.
I've set SpamHalter & Content Control to MOVE not delete..  Would I still get the same message ??
<p>Thanks David.</p><p>I've set SpamHalter & Content Control to MOVE not delete..  Would I still get the same message ??</p><p>Thanks </p>
