[quote user="ineuw"]
The system message window reports Warning! Spamhalter not found folder for Spam! when in fact there is a Junk or suspicious mail folder under My Mailbox. This folder is also indicated in Content control of the \Tools\Spam and content controls.
Is this an error? And if it is, how can I correct it?
Thanks in advance,
ineuw
It is an error when you actually have enabled Spamhalter under Tools -> Spam... -> Spamhalter. If that is activated, then re-select the folder to use. If you don't use Spamhalter, it's no problem.
[quote user="ineuw"]<p>The system message window reports <b>Warning! Spamhalter not found folder for Spam! </b>when in fact there is a Junk or suspicious mail folder under My Mailbox.&nbsp; This folder is also indicated in Content control of the \Tools\Spam and content controls.
</p><p>Is this an error? And if it is, how can I correct it?</p><p>Thanks in advance,&nbsp;</p><p>&nbsp;ineuw</p><p>[/quote]</p><p>It is an error when you actually have enabled Spamhalter under Tools -&gt; Spam... -&gt; Spamhalter. If that is activated, then re-select the folder to use. If you don't use Spamhalter, it's no problem.</p><p>&nbsp;
&nbsp;</p>
Han van den Bogaerde - support@vandenbogaerde.net
Member of Pegasus Mail Support Group.
My own Pegasus Mail related web information:
http://www.vandenbogaerde.net/pegasusmail/
