PMail, Mapi and Corel photo album 6 problem
with Corel Photo Album 6  and other photo album software, yes, it does.
<p>with Corel Photo Album 6  and other photo album software, yes, it does.</p><p>[:)]</p><p> </p>
Here is my solution for using Pegasus Mail with Corel photo Album 6
1) Pegasus mail must be the default system emailer
2) You have to unpack the file mapi32.dll included in wpmmapi.exe, and
rename it like mapi32x.dll.
3) Copy this file in c:\windows\system32\
4) add this key in registry base :
hkey_local_machine/software/clients/mail/pegasus
(string), type : REG-SZ
Data : c:\windows\system32\mapi32x.dll
<p>Here is my solution for using Pegasus Mail with Corel photo Album 6 </p><p>1) Pegasus mail must be the default system emailer </p><p>2) You have to unpack the file mapi32.dll included in wpmmapi.exe, and rename it like mapi32x.dll. 3) Copy this file in c:\windows\system32\ 4) add this key in registry base : hkey_local_machine/software/clients/mail/pegasus </p><p>(string), type : REG-SZ </p><p>name : DLLPath Data : c:\windows\system32\mapi32x.dll </p>
And this works without running the actual MAPI installer? I'm very interested if it does.
-- David --
And this works without running the actual MAPI installer? I'm very interested if it does. Cheers! -- David --
