Lost 'keep a copy' options
Brilliant.  Thank you.  The state file change worked.
Eric
<p>Brilliant.  Thank you.  The state file change worked.</p><p>Eric </p>
My Pmail (4.41) has stopped offering my folders as an option for 'copies to self'.  On sending, the dialogue appears, but after answering 'yes' to 'keep a copy', nothing else happens except I still have to assign a folder for the copy before Pmail will allow any other action - as has been the norm - but the folder assignment graphic has disappeared.  The same situation is happening when I attempt to 'move' a message to another folder.  Has anyone else seen this?  Eric
[quote user="erichager"]My Pmail (4.41) has stopped offering my folders as an option for 'copies to self'.  On sending, the dialogue appears, but after answering 'yes' to 'keep a copy', nothing else happens except I still have to assign a folder for the copy before Pmail will allow any other action - as has been the norm - but the folder assignment graphic has disappeared.  The same situation is happening when I attempt to 'move' a message to another folder.  Has anyone else seen this?  Eric
The only thing I can think of is that the window opens outside the visible area. When this happens try Windows -> tile if that works. If not, you might need to start with a fresh state.pmj.
Find the Home mailbox directory (using Help -> About Pegasus Mail -> Info)
Close down Pegasus Mail
In the foud directory rename state.pmj to state.sav (te be able to revert)
Restart Pegasus Mail, that might do the trick.
<p>[quote user="erichager"]My Pmail (4.41) has stopped offering my folders as an option for 'copies to self'.  On sending, the dialogue appears, but after answering 'yes' to 'keep a copy', nothing else happens except I still have to assign a folder for the copy before Pmail will allow any other action - as has been the norm - but the folder assignment graphic has disappeared.  The same situation is happening when I attempt to 'move' a message to another folder.  Has anyone else seen this?  Eric [/quote]</p><p>The only thing I can think of is that the window opens outside the visible area. When this happens try Windows -> tile if that works. If not, you might need to start with a fresh state.pmj.</p>Find the Home mailbox directory (using Help -> About Pegasus Mail -> Info) Close down Pegasus Mail In the foud directory rename state.pmj to state.sav (te be able to revert) Restart Pegasus Mail, that might do the trick.<p> </p>
