Problem sending hyperlinks
[quote user="PaulW"]
How are sending it - text or HTML?
You say you can open it in gmail - does that mean it's not the sending that's at fault, but the interpreting by the receiver?
Thanks to both of you for your replies.
Sent as HTML. Using the paste special command with no wrapping fixed it.
[quote user="PaulW"] <P>How are sending it - text or HTML?</P> <P>You say you can open it in gmail - does that mean it's not the sending that's at fault, but the interpreting by the receiver?</P> <P> </P> <P>[/quote]</P> <P>Thanks to both of you for your replies.</P> <P>Sent as HTML. Using the paste special command with no wrapping fixed it.</P> <P>Cheers!</P>
Hi
Using Pegasus Mail to send a hyperlink. Recipients are unable to use the link:
http://www.itproportal.com/articles/2008/11/12/google-earth-cracks-4th-dimension-brings-back-ancient-rome/
When sent, Pegasus Mail inserts a space between 4th- and dimension. I tried selecting the link and converting it to a hyperlink, but the subsequent hyperlink only includes the 'http://www.itproportal.com/articles/2008/11/12/google-earth-cracks-4th-' the remainder is treated as normal text and wraps to the line below when opened by Pegasus Mail. This happens when other Pegasus Mail users open the message and when I open the message using PMail when I send it to myself.
If I open the same message directly from my gmail account online, the link works fine.
How can I configure Pegasus Mail to treat the link as a hyperlink?
<P>Hi</P> <P>Using Pegasus Mail to send a hyperlink. Recipients are unable to use the link:</P> <P><A href="http://www.itproportal.com/articles/2008/11/12/google-earth-cracks-4th-dimension-brings-back-ancient-rome/">http://www.itproportal.com/articles/2008/11/12/google-earth-cracks-4th-dimension-brings-back-ancient-rome/</A></P> <P>When sent, Pegasus Mail inserts a space between 4th- and dimension. I tried selecting the link and converting it to a hyperlink, but the subsequent hyperlink only includes the '<A href="http://www.itproportal.com/articles/2008/11/12/google-earth-cracks-4th-dimension-brings-back-ancient-rome/">http://www.itproportal.com/articles/2008/11/12/google-earth-cracks-4th-</A>' the remainder is treated as normal text and wraps to the line below when opened by Pegasus Mail. This happens when other Pegasus Mail users open the message and when I open the message using PMail when I send it to myself.</P> <P>If I open the same message directly from my gmail account online, the link works fine.</P> <P>How can I configure Pegasus Mail to treat the link as a hyperlink?</P> <P>Thanks</P>
<p>How are sending it - text or HTML?</p><p>You say you can open it in gmail - does that mean it's not the sending that's at fault, but the interpreting by the receiver?</p><p> </p>
Use Paste Special to insert the Url into your message. Select Text Only  Nowrap option when paste'ing
<p>Use Paste Special to insert the Url into your message. Select Text Only  Nowrap option when paste'ing</p><p>Martin </p><p> </p>
