AW: Problem sending mail
Thanks guys for the feedback (and especially the tip concerning my log). I just changed my password, and it seems to work again with PM. I'll keep a close look on the further development though ;)
Hi guys,
this is my first post as a new user, so I'll introduce myself first. My name is Thomas Morwinsky and I've been a happy PM user for almost 13 years. Within the last week an annoying problem came up though (I found similar problems in other threads here, but they didn't really fit to me).
I am located in Germany and use GMX. At first sending mail became unreliable (I did not change any settings in Pegasus; it just came out of the blue), but it worked mostly if I tried several times or re-started PM. For the past two or three days this doesn't work anymore and sending has become impossible, though receiving works fine. In addition, sending through the web-interface of GMX works fine as well.
EDIT: I am using Windows XP Pro on the latest patch-level and PM v.4.41
GMX sent me a mail on March 12th that they will be disabling "APOP" or "CRAM-MD5" authentification after March 16th. That wasn't a problem, since I already used a secure  connection by STARTTLS before (without any issues). I log in by STARTTLS and SMTP authentification with my GMX member number and password (hasn't changed either).
The log I get is like the following:
>> 0025 250-ENHANCEDSTATUSCODES
>> 0010 250-SIZE
>> 0022 250-AUTH=LOGIN PLAIN
>> 0022 250-AUTH LOGIN PLAIN
>> 0014 250 STARTTLS
<< 0010 STARTTLS
>> 0038 220 2.7.0 Ready to start TLS {mp034}
<< 0020 EHLO [192.168.1.2]
>> 0035 250-mail.gmx.net GMX Mailservices
>> 0014 250-8BITMIME
>> 0010 250-SIZE
>> 0014 250 STARTTLS
<< 0012 AUTH LOGIN
>> 0018 334 VXNlcm5hbWU6
<< 0014 MTAyNDc1OTM=
>> 0018 334 UGFzc3dvcmQ6
<< 0014 c2Fpcm9sdmFy
>> 0050 535 5.7.0 Incorrect username or password {mp034}
 The last (mp...) can also take other numbers. I already had mp35, 60, 64 etc.
I also tried the other authentification methods offered by PM, but they produce similar results (I can  post those logs as well if that would help).
It might be a problem specific to my GMX account in PM, since my wife who is on another machine can log in to GMX via PM and send mails using identical authentification method to mine. I can also log in to another provider and send mails via PM through him without any issues. I am really annoyed at the problem with my GMX account, since this is my main account with thousands of archived mails since about 1997.
Thomas
&lt;p&gt;Hi guys, this is my first post as a new user, so I&#039;ll introduce myself first. My name is Thomas Morwinsky and I&#039;ve been a happy PM user for almost 13 years. Within the last week an annoying problem came up though (I found similar problems in other threads here, but they didn&#039;t really fit to me).&lt;/p&gt;&lt;p&gt;I am located in Germany and use GMX. At first sending mail became unreliable (I did not change any settings in Pegasus; it just came out of the blue), but it worked mostly if I tried several times or re-started PM. For the past two or three days this doesn&#039;t work anymore and sending has become impossible, though receiving works fine. In addition, sending through the web-interface of GMX works fine as well.&lt;/p&gt;&lt;p&gt;EDIT: I am using Windows XP Pro on the latest patch-level and PM v.4.41 &lt;/p&gt;&lt;p&gt;GMX sent me a mail on March 12th that they will be disabling &quot;APOP&quot; or &quot;CRAM-MD5&quot; authentification after March 16th. That wasn&#039;t a problem, since I already used a secure&amp;nbsp; connection by STARTTLS before (without any issues). I log in by STARTTLS and SMTP authentification with my GMX member number and password (hasn&#039;t changed either).&lt;/p&gt;&lt;p&gt;The log I get is like the following:&lt;/p&gt;&lt;p&gt;&amp;gt;&amp;gt; 0025 250-ENHANCEDSTATUSCODES &amp;gt;&amp;gt; 0010 250-SIZE &amp;gt;&amp;gt; 0022 250-AUTH=LOGIN PLAIN &amp;gt;&amp;gt; 0022 250-AUTH LOGIN PLAIN &amp;gt;&amp;gt; 0014 250 STARTTLS &amp;lt;&amp;lt; 0010 STARTTLS &amp;gt;&amp;gt; 0038 220 2.7.0 Ready to start TLS {mp034} &amp;lt;&amp;lt; 0020 EHLO [192.168.1.2] &amp;gt;&amp;gt; 0035 250-mail.gmx.net GMX Mailservices &amp;gt;&amp;gt; 0014 250-8BITMIME &amp;gt;&amp;gt; 0025 250-ENHANCEDSTATUSCODES &amp;gt;&amp;gt; 0010 250-SIZE &amp;gt;&amp;gt; 0022 250-AUTH=LOGIN PLAIN &amp;gt;&amp;gt; 0022 250-AUTH LOGIN PLAIN &amp;gt;&amp;gt; 0014 250 STARTTLS &amp;lt;&amp;lt; 0012 AUTH LOGIN &amp;gt;&amp;gt; 0018 334 VXNlcm5hbWU6 &amp;lt;&amp;lt; 0014 MTAyNDc1OTM= &amp;gt;&amp;gt; 0018 334 UGFzc3dvcmQ6 &amp;lt;&amp;lt; 0014 c2Fpcm9sdmFy &amp;gt;&amp;gt; 0050 535 5.7.0 Incorrect username or password {mp034}&lt;/p&gt;&lt;p&gt;&amp;nbsp;The last (mp...) can also take other numbers. I already had mp35, 60, 64 etc. &lt;/p&gt;&lt;p&gt;I also tried the other authentification methods offered by PM, but they produce similar results (I can&amp;nbsp; post those logs as well if that would help).&lt;/p&gt;&lt;p&gt;It might be a problem specific to my GMX account in PM, since my wife who is on another machine can log in to GMX via PM and send mails using identical authentification method to mine. I can also log in to another provider and send mails via PM through him without any issues. I am really annoyed at the problem with my GMX account, since this is my main account with thousands of archived mails since about 1997. &lt;/p&gt;&lt;p&gt;Thanks&lt;/p&gt;&lt;p&gt;Thomas &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
Hello, because you have told you live in germany I would answer in german.
Ich habe seit vielen Jahren einen Mailkonto bei GMX und verwende seit Anfang an Pegasusmail. Mit GMX hatte ich noch nie Sende / Empfangsprobleme, auch nicht seit der kürzlichen Update - Info. Ich verwende mit GMX nur direkte SSL - Verbindungen mit aktivem Fingerprint und Zertifikatsüberprüfung. Als Mailprogramm verwende ich Pmail V4.50 PB DE. Hier eine Mitschrift eines Mailversands mit SMPT - SSL über GMX.
Connect to 'mail.gmx.net' port 465, timeout 40.
12:14:13.515 [*] Connection established to XXX.XXX.XXX.XXX
12:14:13.640 [*] SSL/TLS session established: 3DES, CBC mode, keysize 192 bits
12:14:13.640 [*] Certificate user is cn=mail.gmx.net, o=GMX GmbH, l=Munich, sp=Bayern, c=DE
12:14:13.640 [*] Certificate is valid from Mon Nov 10 14:13:19 2008 to Tue Nov 17 14:12:50 2009
12:14:13.640 [*] Certificate fingerprint is 2E5003F6E5CDC8AC885941C3BD070138
12:14:14.890 >> 0049 220 mail.gmx.net GMX Mailservices ESMTP {mp033}\0D\0A
12:14:14.890 << 0022 EHLO [XXX.XXX.XXX.XXX]\0D\0A
12:14:14.953 >> 0035 250-mail.gmx.net GMX Mailservices\0D\0A
12:14:14.953 >> 0014 250-8BITMIME\0D\0A
12:14:14.953 >> 0025 250-ENHANCEDSTATUSCODES\0D\0A
12:14:14.953 >> 0010 250-SIZE\0D\0A
12:14:14.953 >> 0022 250-AUTH=LOGIN PLAIN\0D\0A
12:14:14.953 >> 0022 250-AUTH LOGIN PLAIN\0D\0A
12:14:14.953 >> 0014 250 STARTTLS\0D\0A
12:14:14.953 << 0012 AUTH LOGIN\0D\0A
12:14:14.015 >> 0018 3 XXXXXXXXXXX\0D\0A
12:14:14.015 << 0014 MXXXXXXXXXXXXXX=\0D\0A
12:14:14.078 >> 0018 3 XXXXXXXXXXXXX\0D\0A
12:14:14.078 << 0022 TXXXXXXXXXXXXXX\0D\0A
12:14:14.140 >> 0028 XXX X.X.X Go ahead {mp033}\0D\0A
12:14:14.140 << 0039 MAIL FROM:<XXXXXXXXXXXX> SIZE=870\0D\0A
.(Mail was send)
Vielleicht hilft ein Protokollvergleich.
&lt;P&gt;Hello, because you have told you live in germany I would answer in german.&lt;/P&gt; &lt;P&gt;Ich habe seit vielen Jahren einen&amp;nbsp;Mailkonto bei GMX und verwende seit Anfang an Pegasusmail. Mit GMX hatte ich noch nie Sende&amp;nbsp;/ Empfangsprobleme, auch nicht seit der k&uuml;rzlichen Update - Info. Ich verwende&amp;nbsp;mit GMX nur direkte SSL - Verbindungen mit aktivem Fingerprint und Zertifikats&uuml;berpr&uuml;fung. Als Mailprogramm verwende ich Pmail V4.50 PB DE. Hier eine Mitschrift eines Mailversands&amp;nbsp;mit SMPT - SSL &uuml;ber GMX. &lt;/P&gt; &lt;P&gt;Connect to &#039;mail.gmx.net&#039; port 465, timeout 40. 12:14:13.515 [*] Connection established to XXX.XXX.XXX.XXX 12:14:13.640 [*] SSL/TLS session established: 3DES, CBC mode, keysize 192 bits 12:14:13.640 [*] Certificate user is cn=mail.gmx.net, o=GMX GmbH, l=Munich, sp=Bayern, c=DE 12:14:13.640 [*] Certificate is valid from Mon Nov 10 14:13:19 2008 to Tue Nov 17 14:12:50 2009 12:14:13.640 [*] Certificate fingerprint is 2E5003F6E5CDC8AC885941C3BD070138 12:14:14.890 &amp;gt;&amp;gt; 0049 220 mail.gmx.net GMX Mailservices ESMTP {mp033}\0D\0A 12:14:14.890 &amp;lt;&amp;lt; 0022 EHLO [XXX.XXX.XXX.XXX]\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0035 250-mail.gmx.net GMX Mailservices\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0014 250-8BITMIME\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0025 250-ENHANCEDSTATUSCODES\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0010 250-SIZE\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0022 250-AUTH=LOGIN PLAIN\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0022 250-AUTH LOGIN PLAIN\0D\0A 12:14:14.953 &amp;gt;&amp;gt; 0014 250 STARTTLS\0D\0A 12:14:14.953 &amp;lt;&amp;lt; 0012 AUTH LOGIN\0D\0A 12:14:14.015 &amp;gt;&amp;gt; 0018 3 XXXXXXXXXXX\0D\0A 12:14:14.015 &amp;lt;&amp;lt; 0014 MXXXXXXXXXXXXXX=\0D\0A 12:14:14.078 &amp;gt;&amp;gt; 0018 3 XXXXXXXXXXXXX\0D\0A 12:14:14.078 &amp;lt;&amp;lt; 0022 TXXXXXXXXXXXXXX\0D\0A 12:14:14.140 &amp;gt;&amp;gt; 0028&amp;nbsp;XXX X.X.X Go ahead {mp033}\0D\0A 12:14:14.140 &amp;lt;&amp;lt; 0039 MAIL FROM:&amp;lt;XXXXXXXXXXXX&amp;gt; SIZE=870\0D\0A . . .(Mail was send)&lt;/P&gt; &lt;P&gt;Vielleicht hilft ein Protokollvergleich.&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt;
I'll answer in german in case anyone else not fluent in german might contribute as well :)
I just altered to send my mail by SSL connection (though without fingerprint) as you suggested. Here's the log:
[*] Connection established to 213.165.64.21
>> 0049 220 mail.gmx.net GMX Mailservices ESMTP {mp007}
>> 0014 250-8BITMIME
>> 0010 250-SIZE
>> 0014 250 STARTTLS
<< 0012 AUTH LOGIN
>> 0050 535 5.7.0 Incorrect username or password {mp007}
I suspect that anything in my local PM GMX account might be corrupt or not working properly, because the error is so specific on this account only and on this machine. Might there be something that I could check in my installation?
EDIT: I just tried mailing using PM from my wife's machine. Same result as on mine. The problem may be with GMX and not my local installation :(
&lt;p&gt;Hi,&lt;/p&gt;&lt;p&gt;I&#039;ll answer in german in case anyone else not fluent in german might contribute as well :) &lt;/p&gt;&lt;p&gt;I just altered to send my mail by SSL connection (though without fingerprint) as you suggested. Here&#039;s the log:&lt;/p&gt;&lt;p&gt;[*] Connection established to 213.165.64.21 &amp;gt;&amp;gt; 0049 220 mail.gmx.net GMX Mailservices ESMTP {mp007} &amp;lt;&amp;lt; 0020 EHLO [192.168.1.2] &amp;gt;&amp;gt; 0035 250-mail.gmx.net GMX Mailservices &amp;gt;&amp;gt; 0014 250-8BITMIME &amp;gt;&amp;gt; 0025 250-ENHANCEDSTATUSCODES &amp;gt;&amp;gt; 0010 250-SIZE &amp;gt;&amp;gt; 0022 250-AUTH=LOGIN PLAIN &amp;gt;&amp;gt; 0022 250-AUTH LOGIN PLAIN &amp;gt;&amp;gt; 0014 250 STARTTLS &amp;lt;&amp;lt; 0012 AUTH LOGIN &amp;gt;&amp;gt; 0018 334 VXNlcm5hbWU6 &amp;lt;&amp;lt; 0014 MTAyNDc1OTM= &amp;gt;&amp;gt; 0018 334 UGFzc3dvcmQ6 &amp;lt;&amp;lt; 0014 c2Fpcm9sdmFy &amp;gt;&amp;gt; 0050 535 5.7.0 Incorrect username or password {mp007} &lt;/p&gt;&lt;p&gt;I suspect that anything in my local PM GMX account might be corrupt or not working properly, because the error is so specific on this account only and on this machine. Might there be something that I could check in my installation?&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;EDIT: I just tried mailing using PM from my wife&#039;s machine. Same result as on mine. The problem may be with GMX and not my local installation :( &lt;/p&gt;
[quote user="Thomas Morwinsky"]
Have you read this on the homepage from GMX?
Originaltext:
Sie sind hier: GMX Hilfe<full_nav><img title="" style="MARGIN: 0px 5px; POSITION: relative; TOP: 2px" alt="-&gt;" src="http://faq.gmx.de/image/misc_pfeil.gif" mce_src="http://faq.gmx.de/image/misc_pfeil.gif">Kommunikation<img title="" style="MARGIN: 0px 5px; POSITION: relative; TOP: 2px" alt="-&gt;" src="http://faq.gmx.de/image/misc_pfeil.gif" mce_src="http://faq.gmx.de/image/misc_pfeil.gif">E-Mail-Programme </full_nav>
Versandbeschränkungen
Leider sind wir gezwungen, bei einigen Benutzern sowohl die Häufigkeit des Versands als auch die Anzahl der möglichen Empfänger zu beschränken. Dies geschieht, um dem Missbrauch unserer Dienste vorzubeugen.
Für nähere Informationen steht Ihnen unser Kundenservice telefonisch zur Verfügung.
[quote user=&quot;Thomas Morwinsky&quot;] &lt;P mce_keep=&quot;true&quot;&gt;EDIT: I just tried mailing using PM from my wife&#039;s machine. Same result as on mine. The problem may be with GMX and not my local installation :( &lt;/P&gt; &lt;P&gt;[/quote]&lt;/P&gt; &lt;P&gt;Have you read this on the homepage from GMX? &lt;/P&gt; &lt;P&gt;Originaltext:&lt;/P&gt; &lt;DIV id=breadcrumb&gt;&lt;STRONG&gt;Sie sind hier:&lt;/STRONG&gt; GMX Hilfe&lt;FULL_NAV&gt;&lt;IMG title=&quot;&quot; style=&quot;MARGIN: 0px 5px; POSITION: relative; TOP: 2px&quot; alt=&quot;-&gt;&quot; src=&quot;http://faq.gmx.de/image/misc_pfeil.gif&quot; mce_src=&quot;http://faq.gmx.de/image/misc_pfeil.gif&quot;&gt;Kommunikation&lt;IMG title=&quot;&quot; style=&quot;MARGIN: 0px 5px; POSITION: relative; TOP: 2px&quot; alt=&quot;-&gt;&quot; src=&quot;http://faq.gmx.de/image/misc_pfeil.gif&quot; mce_src=&quot;http://faq.gmx.de/image/misc_pfeil.gif&quot;&gt;E-Mail-Programme &lt;/FULL_NAV&gt;&lt;/DIV&gt; &lt;P&gt; &lt;TABLE class=&quot;&quot; style=&quot;PADDING-LEFT: 20px&quot; width=740&gt; &lt;TBODY&gt; &lt;TR&gt; &lt;TD class=&quot;&quot; vAlign=top&gt; &lt;H1&gt;Versandbeschr&auml;nkungen&lt;/H1&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt; &lt;TABLE class=&quot;&quot; cellSpacing=0 cellPadding=3 width=540 border=0&gt; &lt;TBODY&gt; &lt;TR&gt; &lt;TD class=&quot;&quot;&gt;Leider sind wir gezwungen, bei einigen Benutzern sowohl die H&auml;ufigkeit des Versands als auch die Anzahl der m&ouml;glichen Empf&auml;nger zu beschr&auml;nken. Dies geschieht, um dem Missbrauch unserer Dienste vorzubeugen. F&uuml;r n&auml;here Informationen steht Ihnen unser &lt;FONT color=#244e7e&gt;Kundenservice&lt;/FONT&gt; telefonisch zur Verf&uuml;gung.&lt;/TD&gt;&lt;/TR&gt;&lt;/TBODY&gt;&lt;/TABLE&gt;&lt;/P&gt;&lt;/TD&gt;&lt;/TR&gt;&lt;/TBODY&gt;&lt;/TABLE&gt;&lt;/P&gt;
Now would be a very good time to get hold of GMX support & change your password.
It may solve your problem if the error message is correct, but the base64 account details above are 'encoded' not 'encrypted', and you have just announced you username & password to the world :)
[quote user=&quot;Thomas Morwinsky&quot;]&lt;p&gt; &amp;gt;&amp;gt; 0018 334 VXNlcm5hbWU6 &amp;lt;&amp;lt; 0014 MTAyNDc1OTM= &amp;gt;&amp;gt; 0018 334 UGFzc3dvcmQ6 &amp;lt;&amp;lt; 0014 c2Fpcm9sdmFy &amp;gt;&amp;gt; 0050 535 5.7.0 &lt;b&gt;Incorrect username or password&lt;/b&gt; {mp007} &lt;/p&gt;&lt;p&gt;I suspect that anything in my local PM GMX account might be corrupt or not working properly, because the error is so specific on this account only and on this machine. Might there be something that I could check in my installation?&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;EDIT: I just tried mailing using PM from my wife&#039;s machine. Same result as on mine. The problem may be with GMX and not my local installation :( &lt;/p&gt;&lt;p&gt;[/quote]&lt;/p&gt;&lt;p&gt;Now would be a very good time to get hold of GMX support &amp;amp; change your password.&lt;/p&gt;&lt;p&gt;It may solve your problem if the error message is correct, but the base64 account details above are &#039;encoded&#039; not &#039;encrypted&#039;, and you have just announced you username &amp;amp; password to the world :)&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
