PMail Hangs when using RQUOTES
Would it help to send the PMS file(s) that I have to see if it is in the files, if there is a way to send them?  I'll experiment to see if I can find a root cause.
<p>Would it help to send the PMS file(s) that I have to see if it is in the files, if there is a way to send them?  I'll experiment to see if I can find a root cause.  </p>
I have been using PMail for many years and today attempted to use the RQuotes variable signature feature.  I was able to successfully compile the RSC file and then copy it to my mail folder as a PMS file.  If I edit the Signature to include a ~! where I would like the quote, when it attempts to add the signature, PMAIL hangs.  If I check Task Manager, it is running full CPU resource and does not stop until I Stop the Process.  I left it for nearly 5 minutes the second time.  I then tried to use the default RQUOTES.R and created the RSC and PMS from that.  Same issue.  If I remove the file, program works fine.  If I remove the ~! from sig, it works fine.  Add both back in and it hangs.  I have tried this on both a C Drive install and my Windows shared network install with the same results.
Any help would be appreciated.
Best Regards,
Stephen Kovacsiss
<p>I have been using PMail for many years and today attempted to use the RQuotes variable signature feature.  I was able to successfully compile the RSC file and then copy it to my mail folder as a PMS file.  If I edit the Signature to include a ~! where I would like the quote, when it attempts to add the signature, PMAIL hangs.  If I check Task Manager, it is running full CPU resource and does not stop until I Stop the Process.  I left it for nearly 5 minutes the second time.  I then tried to use the default RQUOTES.R and created the RSC and PMS from that.  Same issue.  If I remove the file, program works fine.  If I remove the ~! from sig, it works fine.  Add both back in and it hangs.  I have tried this on both a C Drive install and my Windows shared network install with the same results.</p><p> </p><p>Any help would be appreciated.</p><p> Best Regards,</p><p>Stephen Kovacsiss  </p>
[quote user="StephenKovacsiss"]
Best Regards,
Stephen Kovacsiss
I had this problem also when setting up Plato which, I think, is essentially the same thing you're trying to do.  The only way the quote feature worked without hanging was to use the quote only in plain content.  If I tried to add the quote in formatted content with the "add varient at message creation" box checked, pmail would hang as soon as I opened a new message.
[quote user="StephenKovacsiss"] <P>I have been using PMail for many years and today attempted to use the RQuotes variable signature feature.  I was able to successfully compile the RSC file and then copy it to my mail folder as a PMS file.  If I edit the Signature to include a ~! where I would like the quote, when it attempts to add the signature, PMAIL hangs.  If I check Task Manager, it is running full CPU resource and does not stop until I Stop the Process.  I left it for nearly 5 minutes the second time.  I then tried to use the default RQUOTES.R and created the RSC and PMS from that.  Same issue.  If I remove the file, program works fine.  If I remove the ~! from sig, it works fine.  Add both back in and it hangs.  I have tried this on both a C Drive install and my Windows shared network install with the same results.</P> <P mce_keep="true"> </P> <P>Any help would be appreciated.</P> <P> Best Regards,</P> <P>Stephen Kovacsiss</P> <P>[/quote]</P> <P>I had this problem also when setting up Plato which, I think, is essentially the same thing you're trying to do.  The only way the quote feature worked without hanging was to use the quote only in plain content.  If I tried to add the quote in formatted content with the "add varient at message creation" box checked, pmail would hang as soon as I opened a new message.</P>
You are correct.  That is the problem.  The only way that I found to work around it was:
  • Edit the signature to include the quote for variant: Internet address, plain content
  • Select "Add this variant of the default signature upon message creation"
  • Select Variant: Internet address, plain content
Other combinations cause Pegasus to hang.  Not sure if David and his team are aware of this or not.
Thanks for the help,
Stephen
<p>You are correct.  That is the problem.  The only way that I found to work around it was:</p><ul><li>Edit the signature to include the quote for variant: Internet address, plain content </li><li>Select "Add <img src="file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot-1.jpg" alt=""><img src="file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot.jpg" alt="">this variant of the default signature upon message creation"</li><li>Select Variant: Internet address, plain content</li></ul><p>Other combinations cause Pegasus to hang.  Not sure if David and his team are aware of this or not.</p><p>Thanks for the help,</p><p>Stephen </p>
I can't reproduce this one here, sorry. I'm not quite sure what to suggest.
-- David --
[quote user="StephenKovacsiss"]<p>You are correct.  That is the problem.  The only way that I found to work around it was:</p><ul><li>Edit the signature to include the quote for variant: Internet address, plain content </li><li>Select "Add <img src="file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot-1.jpg" mce_src="file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot-1.jpg" alt=""><img src="file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot.jpg" mce_src="file:///C:/DOCUME%7E1/Stephen/LOCALS%7E1/Temp/moz-screenshot.jpg" alt="">this variant of the default signature upon message creation"</li><li>Select Variant: Internet address, plain content</li></ul><p>Other combinations cause Pegasus to hang.  Not sure if David and his team are aware of this or not.</p><p>[/quote] I can't reproduce this one here, sorry. I'm not quite sure what to suggest. Cheers! -- David --  </p>
Hello!
What one may have to pay attention to is that "rescom.exe" uses (DOS-)codepage 850.
I have been told that Notepad does not provide that codepage, so creating "rquotes.r" within Notepad would cause the high-bitted characters in the file to be encoded wrongly (and perhaps cause other unexpected results as well). In order to prevent that, you should create / edit "rquotes.exe" with a DOS-editor (like Edit [that you can open in a DOS-window under Windows]).
(As I have never used any variable signatures, I can only tell what others told me. That is why I am not sure whether this really helps. : -( )
<p> </p><p>Hello!</p><p> </p><p>What one may have to pay attention to is that "rescom.exe" uses (DOS-)codepage 850.</p><p>I have been told that Notepad does not provide that codepage, so creating "rquotes.r" within Notepad would cause the high-bitted characters in the file to be encoded wrongly (and perhaps cause other unexpected results as well). In order to prevent that, you should create / edit "rquotes.exe" with a DOS-editor (like Edit [that you can open in a DOS-window under Windows]).</p><p> </p><p>(As I have never used any variable signatures, I can only tell what others told me. That is why I am not sure whether this really helps. : -( )</p><p> </p>
[quote user="Thomas Nimmesgern"]
Tried that and no-go.  Behaviour is exactly the same as it was with using notepad.  I have had text issues in the past which turned out to be video incompatibilities.  This rescom thing is pretty ancient from what I understand and it just may not be handled properly by certain video setups. It works good enough for me so I guess I'm gonna live with it.  It doesn't hang if I uncheck the "add variant on message creation" check box, OR if that is checked I am in "internet plain content".
Thanks for your reply
<P>[quote user="Thomas Nimmesgern"] </P> <P>I have been told that Notepad does not provide that codepage, so creating "rquotes.r" within Notepad would cause the high-bitted characters in the file to be encoded wrongly (and perhaps cause other unexpected results as well). In order to prevent that, you should create / edit "rquotes.exe" with a DOS-editor (like Edit [that you can open in a DOS-window under Windows]).</P> <P>[/quote]</P> <P>Tried that and no-go.  Behaviour is exactly the same as it was with using notepad.  I have had text issues in the past which turned out to be video incompatibilities.  This rescom thing is pretty ancient from what I understand and it just may not be handled properly by certain video setups. It works good enough for me so I guess I'm gonna live with it.  It doesn't hang if I uncheck the "add variant on message creation" check box, OR if that is checked I am in "internet plain content".</P> <P>Thanks for your reply</P>
I have even tried this with the default rquotes.r file that is in the Resource directory with the same result.  When I used that file, I did not modify it at all.
<p>I have even tried this with the default rquotes.r file that is in the Resource directory with the same result.  When I used that file, I did not modify it at all. </p>
