MALIAS.EXE doesn't work on 64-bit Servers
The 32-bit version of malias.exe was unfortunately never included in the Mercury/32 installers, even though it was intended to be. Thanks for pointing this out, Chris! It's now available as a separate download from here:
http://community.pmail.com/files/folders/utils/entry28372.aspx
<p>The 32-bit version of malias.exe was unfortunately never included in the Mercury/32 installers, even though it was intended to be. Thanks for pointing this out, Chris! It's now available as a separate download from here:</p><p><a href="http://community.pmail.com/files/folders/utils/entry28372.aspx">http://community.pmail.com/files/folders/utils/entry28372.aspx</a></p><p><a href="http://community.pmail.com/files/folders/utils/entry28372.aspx"></a>/Rolf </p>
It looks like that MALIAS.EXE is a 16 bit application which can't bei run by WOW64. Are there any other tools to compile the Mercury alias file?
Regards,
Gerhard
<P>It looks like that MALIAS.EXE is a 16 bit application which can't bei run by WOW64. Are there any other tools to compile the Mercury alias file?</P> <P>Regards, Gerhard</P>
You can have a look at the source for our mercurysynch software - it composes the alias.mer files manually from an external database.
The source is available at http://community.pmail.com/files/folders/codesnippets/entry167.aspx
<P>You can have a look at the source for our mercurysynch software - it composes the alias.mer files manually from an external database.</P> <P>The source is available at <A href="http://community.pmail.com/files/folders/codesnippets/entry167.aspx">http://community.pmail.com/files/folders/codesnippets/entry167.aspx</A></P>
MALIAS is a DOS application - I guess MS may finally have decided that they're not going to support DOS apps any more (I suppose I can't really blame them for that).
It should be trivial to recompile it as a Win32 console application, which *should* run on Win64 systems. I'll see if I can get a chance to do that today.
-- David --
<p>MALIAS is a DOS application - I guess MS may finally have decided that they're not going to support DOS apps any more (I suppose I can't really blame them for that). It should be trivial to recompile it as a Win32 console application, which *should* run on Win64 systems. I'll see if I can get a chance to do that today. Cheers! -- David --  </p>
Just some more on this: I've now recompiled malias.exe as a Win32 console application. It will be a standard part of v4.5, but anyone who desperately needs a copy earlier than that can e-mail me.
-- David --
Just some more on this: I've now recompiled malias.exe as a Win32 console application. It will be a standard part of v4.5, but anyone who desperately needs a copy earlier than that can e-mail me. Cheers! -- David --
I'm using 4.73 and it appears to still have a 16bit version of malias.
I can't find a link to download the 32bit version.
<p>I'm using 4.73 and it appears to still have a 16bit version of malias.</p><p>I can't find a link to download the 32bit version. </p>
There is no 32 bit version of this program.  To run 16-bit MSDOS programs on your 64-bit Windows systems (and Linux) get a copy of DOSBox. This is quite handy to have around when you have old MSDOS utilities to run.
http://www.dosbox.com/
> I'm using 4.73 and it appears to still have a 16bit version of malias. > I can't find a link to download the 32bit version. There is no 32 bit version of this program.  To run 16-bit MSDOS programs on your 64-bit Windows systems (and Linux) get a copy of DOSBox. This is quite handy to have around when you have old MSDOS utilities to run. http://www.dosbox.com/
David's post suggests otherwise, but I was able to get malias running with dosbox and a simple script
c:
cd "C:\Program Files (x86)\DOSBox-0.74\"
dosbox -c "mount D D:\common\mercury" -c "D:" -c "malias mercury\alias.src mercury\alias.mer" -c "exit"
Works like a charm.
Chris
<p>David's post suggests otherwise, but I was able to get malias running with dosbox and a simple script</p><p><span class="Apple-tab-span" style="white-space: pre; "> </span>c:</p><p><span class="Apple-tab-span" style="white-space:pre"> </span>cd "C:\Program Files (x86)\DOSBox-0.74\"</p><p><span class="Apple-tab-span" style="white-space:pre"> </span>dosbox -c "mount D D:\common\mercury" -c "D:" -c "malias mercury\alias.src mercury\alias.mer" -c "exit"</p><p> </p><p>Works like a charm. </p><p>Thanks</p><p>Chris</p><p> </p>
