> he configurado el correo saliente y ahora logré la autenticación correcta para el envío pero pegasus me devuelve este error
> 550 5.7.1 Client does not have permissions to send as this sender
> ¿cómo lo puedo solucionar?
> Gracias, desde ya
> I've configured the outgoing email and now I got the correct authentication for sending but I get this error pegasus
> 550 5.7.1 Client not does have permissions to send as this sender
> How I can fix it?
> Thank you, from now
Looks like you do not have the proper authentication for this sender
David Harris has implemented ESMTP AUTH CRAM-MD5 for WinPMail. It does a SMTP authentication in accordance with RFCs 2554 and 2195. It will also do the LOGIN and the strange MS AUTH=LOGIN.
Go to Tools | Internet options | (Sending) SMTP, edit the SMTP configuration, select the "Security" tab and then select the SMTP Authorization option as specified by your ISP. Most require the the second or third SMTP Authorization option
There are some ISPs that advertise CRAM-MD5 but do not support it. In this case you should try using v4.5 or later. It has an option to fall back to the less secure options.
Do not use CRAM-MD5 authentication even if it is advertised
The process of logging into the SMTP server to authenticate your identity can take a variety of forms: the server "advertises" the forms it understands, and Pegasus Mail looks through that list, choosing the most secure form it recognizes. Some forms are very "weak", in that they either transmit your credentials as clear text or in a form that can be easily broken, while other forms are "strong", in the sense that it is very difficult to work out your credentials simply by observing the exchange of data between the two programs. Unfortunately, one of the strongest forms of authentication, called CRAM-MD5, is commonly misconfigured on SMTP servers, even at quite reputable ISPs - the server will advertise that it supports it, but will actually fail any attempt to use it. Getting the ISP to realize that they are at fault is a lost cause in most cases - it's almost always easier simply to check this control, which tells Pegasus Mail never to use CRAM-MD5 for this server. You should be aware that you reduce the security of your connection by checking this control: CRAM-MD5 is the only commonly-used authentication form that offers reasonable security, and by disabling it, you force Pegasus Mail to use less secure methods... But sometimes you may decide that being able to send mail is more important than being able to do it securely. The choice is yours.
Parece que no tienen la debida autenticación de este remitente
David Harris ha puesto en marcha ESMTP AUTH CRAM-MD5 para WinPMail. Lo hace de una autenticación SMTP, de acuerdo con RFC 2554 y 2195. También se hará el LOGIN y el extraño MS AUTH LOGIN =.
Ir a Herramientas | Opciones de Internet | (envío) SMTP, modificar la configuración de SMTP, seleccione la pestaña "Seguridad" y luego seleccione la opción Autorización SMTP tal como se especifica por su ISP. La mayoría requiere el la segunda o tercera opción SMTP autorización
Hay algunos proveedores de Internet que anuncian CRAM-MD5, pero no lo apoyo. En este caso deberías intentar usar v4.5 o posterior. Tiene la opción de recurrir a las opciones menos seguras.
No utilizar la autenticación CRAM-MD5, incluso si se anuncia
El proceso de registro en el servidor de SMTP para autenticar su identidad puede adoptar diversas formas: el servidor "anuncia" las formas que entiende, y Pegasus Mail mira a través de esa lista, la elección de la forma más segura que reconoce. Algunas formas son muy "débiles", en que, o bien transmitir sus credenciales como texto o en una forma que puede romperse con facilidad, mientras que otras formas son "fuertes", en el sentido de que es muy difícil de resolver sus credenciales simplemente al observar el intercambio de datos entre los dos programas. Desafortunadamente, una de las formas más fuertes de autenticación, llamado CRAM-MD5, es incorrectas más comunes en los servidores de SMTP, incluso a los ISPs muy buena reputación - el servidor publicidad que da soporte, pero en realidad se producirá un error cualquier intento de uso. Obtener el ISP para darse cuenta de que tienen la culpa es una causa perdida en la mayoría de los casos - es casi siempre más fácil simplemente para comprobar este control, que dice Pegasus Mail no utilizar nunca CRAM-MD5 para este servidor. Usted debe ser consciente de que reducir la seguridad de su conexión marcando este control: CRAM-MD5 es la forma de autenticación sólo de uso común que ofrece una seguridad razonable, y mediante la desactivación de ella, la fuerza de Pegasus Mail para utilizar métodos menos seguros ... Pero a veces usted puede decidir que ser capaz de enviar correo es más importante que ser capaz de hacerlo con seguridad. La elección es suya.
> Gracias, desde ya
> How I can fix it?
> Thank you, from now
