Pegasus Mail Suggestions
PM461 not works in WinPE environment
I've sent to beta-reports@pmail.gen.nz
<p>I've sent to beta-reports@pmail.gen.nz</p><p> </p>
Hello:
I've using PM 4.52  on a pendrive with Active@ Boot Disk (WinPE 2.0
operating environment) over a year and (WinPE 3.0
operating environment) over several months with no problems, but with the upgrade to PM461 it not works anymore.
Best wishes.
Aldo
<p>Hello:</p><p>I've using PM 4.52  on a pendrive with Active@ Boot Disk (WinPE 2.0 operating environment) over a year and (WinPE 3.0 operating environment) over several months with no problems, but with the upgrade to PM461 it not works anymore.</p><p>Best wishes.</p><p>Aldo</p><p> </p>
[quote user="aga60"]I've using PM 4.52  on a pendrive[/quote]
What's WinPE? And what happens when it doesn't work? Any error messages?
<p>[quote user="aga60"]I've using PM 4.52  on a pendrive[/quote]</p><p>What's WinPE? And what happens when it doesn't work? Any error messages?</p>
Hello Michael:
1) (from wikipedia) Windows Preinstallation Environment (aka Windows PE, WinPE) is a lightweight version of Windows XP, Windows Server 2003, Windows Vista, Windows 7, or Windows Server 2008 R2 that is used for the deployment of workstations and servers. It is intended as a 32-bit or 64-bit replacement for MS-DOS during the installation phase of Windows, and can be booted via PXE, CD-ROM, USB flash drive, or hard disk
I've using it in way to have a bootable windows pendrive with portable apps.
 2) After to select a message to read, before displaying it, appears an alert window like:
"The instruction at 0x036a6c3f referenced memory at  0x00000048.
The memory could not be read.
 Click on OK to terminate the program"
<p>Hello Michael:</p><p>1) (from wikipedia) <b>Windows Preinstallation Environment</b> (aka <b>Windows PE</b>, <b>WinPE</b>) is a lightweight version of <a href="http://en.wikipedia.org/wiki/Windows_XP">Windows XP</a>, <a href="http://en.wikipedia.org/wiki/Windows_Server_2003">Windows Server 2003</a>, <a href="http://en.wikipedia.org/wiki/Windows_Vista">Windows Vista</a>, <a href="http://en.wikipedia.org/wiki/Windows_7">Windows 7</a>, or <a href="http://en.wikipedia.org/wiki/Windows_Server_2008_R2">Windows Server 2008 R2</a> that is used for the deployment of workstations and servers. It is intended as a <a href="http://en.wikipedia.org/wiki/32-bit">32-bit</a> or <a href="http://en.wikipedia.org/wiki/64-bit">64-bit</a> replacement for <a href="http://en.wikipedia.org/wiki/MS-DOS">MS-DOS</a> during the installation phase of Windows, and can be <a href="http://en.wikipedia.org/wiki/Booting" title="Booting">booted</a> via <a href="http://en.wikipedia.org/wiki/Preboot_Execution_Environment" title="Preboot Execution Environment">PXE</a>, <a href="http://en.wikipedia.org/wiki/CD-ROM">CD-ROM</a>, <a href="http://en.wikipedia.org/wiki/USB_flash_drive">USB flash drive</a>, or <a href="http://en.wikipedia.org/wiki/Hard_disk" class="mw-redirect" title="Hard disk">hard disk</a>.  </p><p>I've using it in way to have a bootable windows pendrive with portable apps.</p><p> 2) After to select a message to read, before displaying it, appears an alert window like:</p><p> "The instruction at 0x036a6c3f referenced memory at  0x00000048.</p><p>The memory could not be read.</p><p> Click on OK to terminate the program"</p><p> </p>
[quote user="aga60"] 2) After to select a message to read, before displaying it, appears an alert window like:[/quote]
HTML message, plain text or any?
<p>[quote user="aga60"] 2) After to select a message to read, before displaying it, appears an alert window like:[/quote]</p><p>HTML message, plain text or any?</p>
In both types of  messages.
<p>In both types of  messages.</p><p> </p>
[quote user="aga60"]In both types of  messages. [/quote]
Looks like you need to download and install the MiniDump tool for providing more details about your issue: Please read its ReadMe file for instructions, you most probably need to run its "stand-alone" mode via its Start menu group entry called Pegasus Mail Debugger for successfully creating a crash dump - if it works at all in your environment.
<p>[quote user="aga60"]In both types of  messages. [/quote]</p><p>Looks like you need to download and install the <a href="/files/folders/community_add-ons_for_pegasus_mail/entry12763.aspx" mce_href="/files/folders/community_add-ons_for_pegasus_mail/entry12763.aspx" target="_blank">MiniDump tool</a> for providing more details about your issue: Please read its ReadMe file for instructions, you most probably need to run its "stand-alone" mode via its Start menu group entry called <em>Pegasus Mail Debugger</em> for successfully creating a crash dump - if it works at all in your environment.</p>
I'm downloading it.
Thank you.
<p>I'm downloading it.</p><p>Thank you.</p><p> </p>
Last week I've sent a dump.
I hope that will be useful .
Thanks.
Aldo
<p>Last week I've sent a dump.</p><p>I hope that will be useful .</p><p>Thanks.</p><p>Aldo</p><p> </p>
[quote user="aga60"]Last week I've sent a dump.[/quote]
If you didn't get a reply we didn't get the dump, where did you send it and did you include a reference to this thread (as I don't know your real name I can't tell who's who from the emails we get)?
<p>[quote user="aga60"]Last week I've sent a dump.[/quote]</p><p>If you didn't get a reply we didn't get the dump, where did you send it and did you include a reference to this thread (as I don't know your real name I can't tell who's who from the emails we get)?</p>
OK, I'm sending it another time with next subject: "dump from PM461 ref: user:aga60, subject:PM461 not works in WinPE environment"
Aldo
<p>OK, I'm sending it another time with next subject: "dump from PM461 ref: user:aga60, subject:PM461 not works in WinPE environment"</p><p>Aldo</p><p> </p><p> </p>
