Remote-linked graphics problem
Thanks for the tip Martin.
It seems to work, no downloads in this particular mail.
Regards,
Maikel
<p>Thanks for the tip Martin. It seems to work, no downloads in this particular mail.</p><p>Regards,</p><p>Maikel </p>
I have selected to
manually download remote-linked graphics.
However, every now and
then I receive emails that automatically dp download images in the
preview mode. Mind you, not all images are downloaded. It's just one
or two of them.
I'm using Pegasus 4.41 with Bearhtml 3.0.2.
Any idea how to prevent
this from happening?
Kind regards,
Maikel
<p>Hello,</p><p> </p><p style="margin-bottom: 0cm;" lang="en-GB">I have selected to manually download remote-linked graphics.</p> <p style="margin-bottom: 0cm;" lang="en-GB">However, every now and then I receive emails that automatically dp download images in the preview mode. Mind you, not all images are downloaded. It's just one or two of them.</p><p style="margin-bottom: 0cm;" lang="en-GB">I'm using Pegasus 4.41 with Bearhtml 3.0.2. </p> <p style="margin-bottom: 0cm;" lang="en-GB">Any idea how to prevent this from happening?</p> <p style="margin-bottom: 0cm;" lang="en-GB">Kind regards,</p> <p style="margin-bottom: 0cm;" lang="en-GB">Maikel</p><p style="margin-bottom: 0cm;" lang="en-GB"> </p> <p style="margin-bottom: 0cm;" lang="en-GB"></p>
Are you sure the ones that do get displayed automatically are remote images and not embedded images that have been sent with the email? Did you check the source to see?
Are you sure the ones that do get displayed automatically [I]are[/I] remote images and not embedded images that have been sent with the email? Did you check the source to see?
Hello Mike,
Thanks for your reply. Yes I did check and also see a "Downloading" message in the Pegasus status bar.
I just checked again, to be sure. I noticed that the one that is downloaded originated from another domain as the rest of the images and doesn't seem to have an image extension.
I have copied the image tag from the mail:
<img src=3D"http://ad.nl.doubleclick.net/ad/nieuwsbrief.dqa.nl/niet=leden_Bottom;tile=3D1;sz=3D468x60;ord=3D123456789?" width=3D"468" height=3D=
"60" border=3D"0" alt=3D"" />
Regards,
Maikel
&lt;p&gt;Hello Mike,&lt;/p&gt;&lt;p&gt;Thanks for your reply. Yes I did check and also see a &quot;Downloading&quot; message in the Pegasus status bar. &lt;/p&gt;&lt;p&gt;I just checked again, to be sure. I noticed that the one that is downloaded originated from another domain as the rest of the images and doesn&#039;t seem to have an image extension.&lt;/p&gt;&lt;p&gt;I have copied the image tag from the mail:&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;lt;img src=3D&quot;http://ad.nl.doubleclick.net/ad/nieuwsbrief.dqa.nl/niet=leden_Bottom;tile=3D1;sz=3D468x60;ord=3D123456789?&quot; width=3D&quot;468&quot; height=3D= &quot;60&quot; border=3D&quot;0&quot; alt=3D&quot;&quot; /&amp;gt; &lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;p&gt;Maikel&amp;nbsp;&lt;/p&gt;
[quote user="Maikel"]
Hello Mike,
Thanks for your reply. Yes I did check and also see a "Downloading" message in the Pegasus status bar.[/quote]
Thank you. Obvious question and interesting to know the answer.
[quote] ... doesn't seem to have an image extension.[/quote]
I wonder if that's relevant or not ...
[quote]I have copied the image tag from the mail:
Do you use a hosts file? See, e.g. Wikipedia on that.
That's not a full answer--which is beyond me--and is maybe not the answer you're looking for, but I wonder if adding
to a hosts file would effectively block it.
[quote user=&quot;Maikel&quot;] &lt;P&gt;Hello Mike,&lt;/P&gt; &lt;P&gt;Thanks for your reply. Yes I did check and also see a &quot;Downloading&quot; message in the Pegasus status bar.[/quote]&lt;/P&gt; &lt;P&gt;Thank you. Obvious question and interesting to know the answer.&lt;/P&gt; &lt;P&gt;[quote] ...&amp;nbsp;doesn&#039;t seem to have an image extension.[/quote]&lt;/P&gt; &lt;P&gt;I wonder if that&#039;s relevant or not ...&lt;/P&gt; &lt;P&gt;[quote]I have copied the image tag from the mail:&amp;nbsp;&lt;/P&gt; &lt;P&gt;&amp;lt;img src=3D&quot;http://ad.nl.doubleclick.net/ad/nieuwsbrief.dqa.nl/niet=leden_Bottom;tile=3D1;sz=3D468x60;ord=3D123456789?&quot; width=3D&quot;468&quot; height=3D= &quot;60&quot; border=3D&quot;0&quot; alt=3D&quot;&quot; /&amp;gt; [/quote]&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;Do you use a hosts file? See, e.g. Wikipedia on that.&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;That&#039;s not a full answer--which is beyond me--and is maybe not the answer you&#039;re looking for, but I wonder if adding&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;ad.nl.doubleclick.net&lt;/P&gt; &lt;P mce_keep=&quot;true&quot;&gt;&amp;nbsp;&lt;/P&gt; &lt;P&gt;to a hosts file would effectively block it.&lt;/P&gt;
I have investigated this problem, and a fix will be available in version 3.0.3 of Bearhtml.  It is caused by the lack of a legitimate filename. The question mark tells the web server to execute a script to generate the image.   I will only allow this request to be made if fetching remote graphics is allowed/requested.
Thanks for heads up
&lt;p&gt;I have investigated this problem, and a fix will be available in version 3.0.3 of Bearhtml.&amp;nbsp; It is caused by the lack of a legitimate filename. The question mark tells the web server to execute a script to generate the image.&amp;nbsp;&amp;nbsp; I will only allow this request to be made if fetching remote graphics is allowed/requested. &lt;/p&gt;&lt;p&gt;Thanks for heads up&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;Martin&amp;nbsp;&lt;/p&gt;
Hello Martin,
Thanks for looking at my problem so quickly.
I will be eagerly waiting for the new version.
Kind regards,
Maikel
&lt;p&gt;Hello Martin,&lt;/p&gt;&lt;p&gt;Thanks for looking at my problem so quickly.&lt;/p&gt;&lt;p&gt;I will be eagerly waiting for the new version.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;Kind regards,&lt;/p&gt;&lt;p&gt;Maikel&amp;nbsp;&lt;/p&gt;
I have placed the hopeful solution on my website as: http://www3.telus.net/public/irelam/bear303.zip. Let me know please if it works for you
martin
&lt;p&gt;I have placed the hopeful solution on my website as: http://www3.telus.net/public/irelam/bear303.zip. Let me know please if it works for you&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;martin&amp;nbsp;&lt;/p&gt;
Hello Martin,
I just installed your update and it seems to work, but I only tested it with some emails that had their images in cache.
Pegasus still reports it's getting data from the cache, but doesn't show the images.
To be really sure I will have to wait until I receive a new mail.
Anyway, thanks for your help.
Maikel
&lt;p&gt;Hello Martin,&lt;/p&gt;&lt;p&gt;I just installed your update and it seems to work, but I only tested it with some emails that had their images in cache. &lt;/p&gt;&lt;p&gt;Pegasus still reports it&#039;s getting data from the cache, but doesn&#039;t show the images. &lt;/p&gt;&lt;p&gt;To be really sure I will have to wait until I receive a new mail.&lt;/p&gt;&lt;p&gt;Anyway, thanks for your help.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;Maikel&amp;nbsp;&lt;/p&gt;
You need not wait, if you clear cache (Shift + Ctrl + Y)
&lt;p&gt;You need not wait, if you clear cache (Shift + Ctrl + Y)&lt;/p&gt;&lt;p&gt;Martin&amp;nbsp;&lt;/p&gt;
