[quote user="oonumberoo"]
I have been using Pegasus for seven years but have recently had problems with the Edit/|Find text... facility, mostly in the New Mail folder. Sometimes it works and then it will not work.
I can 'trick' it into working by opening the Sent folder, doing a search (which usually works) and then returning to the New Mail folder and doing a search, which again, will now usually work.
I do not change any settings, and never change settings between searches. I always use the default settings (multiple/delete results on exist/current folder only/no age or date constraints).
I use Pegasus 4.14 (Win 32) and have searched the site for a previous query of this sort but have found nothing to help.
Any suggestions would be welcomed. Thank you.
Depending on the spot you start a search Pegasus Mail set's the default it uses. So it might very well be that it doesn't look at the new mail folder because you are in a tray or such. You might need to change the options in the Folders to search section.
[quote user="oonumberoo"]<p>I have been using Pegasus for seven years but have recently had problems with the Edit/|Find text... facility, mostly in the New Mail folder. Sometimes it works and then it will not work.</p><p>I can 'trick' it into working by opening the Sent folder, doing a search (which usually works) and then returning to the New Mail folder and doing a search, which again, will now usually work.</p><p>I do not change any settings, and never change settings between searches. I always use the default settings (multiple/delete results on exist/current folder only/no age or date constraints).</p><p>I use Pegasus 4.14 (Win 32) and have searched the site for a previous query of this sort but have found nothing to help.</p><p>Any suggestions would be welcomed. Thank you.
</p><p>[/quote]</p><p>&nbsp;Depending on the spot you start a search Pegasus Mail set's the default it uses. So it might very well be that it doesn't look at the new mail folder because you are in a tray or such. You might need to change the options in the Folders to search section.</p><p>
&nbsp;</p>
Han van den Bogaerde - support@vandenbogaerde.net
Member of Pegasus Mail Support Group.
My own Pegasus Mail related web information:
http://www.vandenbogaerde.net/pegasusmail/
