[quote user="Brian Fluet"]
My understanding of timeout settings is that the timeout set in the General tab of Internet Options gets used when the one in the POP3 and SMTP host configurations is set to zero. This is consistent with what the help file says under "Creating a POP3 Definition:
Timeout: The length of time Pegasus Mail should wait for a reply from the host before concluding that there is a communication problem and giving up. If you enter zero (0) in this field, Pegasus Mail will use the default timeout that appears on the General Internet mail settings page of the Internet Options dialog.
What I have just discovered is that when a host timeout is set to
zero the actual timeout is 30 seconds regardless of what is specified
in the General tab.
My tests consisted of attempted sends and POP3 downloads without an internet connection. The resulting "Network or Protocol Error" windows displays the timeout used for that connection attempt.
I am anxious for others to test this.
I've just confirmed your finding. It seems the 30 sec value is hardcoded. Below the session logs of several accounts of mine.
[quote user="Timeout individually set"]
18:47:34.982: --- 26 May 2020, 18:47:34.982 ---
18:47:35.130: Connect to 'pop.gmx.com', timeout 60 seconds.
18:47:35.142: 2: Bad address "pop.gmx.com"
18:47:44.485: --- 26 May 2020, 18:47:44.485 ---
18:47:44.486: Connect to 'pop.mail.yahoo.com', timeout 100 seconds.
18:47:44.488: 2: Bad address "pop.mail.yahoo.com"
18:47:56.017: --- 26 May 2020, 18:47:56.017 ---
18:47:56.018: Connect to 'pop.gmail.com', timeout 300 seconds.
18:47:56.038: 2: Bad address "pop.gmail.com"
[quote user="General timeout = 120"]
18:58:57.130: --- 26 May 2020, 18:58:57.130 ---
18:58:57.132: Connect to 'pop.gmail.com', timeout 30 seconds.
18:58:57.171: 2: Bad address "pop.gmail.com"
All connection attempts done without an Internet connection.
[quote user="Brian Fluet"]<p>My understanding of timeout settings is that the timeout set in the General tab of Internet Options gets used when the one in the POP3 and SMTP host configurations is set to zero.&nbsp; This is consistent with what the help file says under "Creating a POP3 Definition:
</p><blockquote><p><i>Timeout: The length of time Pegasus Mail should wait for a reply from the host before concluding that there is a communication problem and giving up. If you enter zero (0) in this field, Pegasus Mail will use the default timeout that appears on the General Internet mail settings page of the Internet Options dialog.
</i></p></blockquote><p> What I have just discovered is that when a host timeout is set to
in the General tab.&nbsp;
</p><p>My tests consisted of attempted sends and POP3 downloads without an internet connection. The resulting "Network or Protocol Error" windows displays the timeout used for that connection attempt.
</p><p>I am anxious for others to test this. </p><p>[/quote]</p><p>I've just confirmed your finding. It seems the 30 sec value is hardcoded. Below the session logs of several accounts of mine.</p><p>[quote user="Timeout individually set"]</p><p>18:47:34.982: --- 26 May 2020, 18:47:34.982 ---
</p><p>18:47:44.485: --- 26 May 2020, 18:47:44.485 ---
</p><p>18:47:56.017: --- 26 May 2020, 18:47:56.017 ---
</p><p>[/quote] </p><p>[quote user="General timeout = 120"]</p><p>18:58:57.130: --- 26 May 2020, 18:58:57.130 ---
</p><p>[/quote]</p><p>All connection attempts done without an Internet connection.
