Don't know if this is the correct spot but I'm wondering if Pegasus has a location to check on problems. Sounds goofy but recently I'm getting messages I cannot read...messags from Spectrum AND the USPS regarding packages for example most of the mail come through but a few like mentioned....every time i try to open I get the following.
"Pegasus Mail for Windows has stopped working"
A problem caused the program to stop working corresctly
Windows will close the program and notify you if a solution
is available.
says I will be notified but I never am so I'm wondering if there is a way to find out what the problem actually is so I can correct. As mentioned it happens only on a few
is available.
