[quote user="MikeW"]
I use pmail to download emails via GPRS connection. Every byte of GPRS traffic is very expensive. (foreigen country)
So, im looking for the best solution to show the email header and than decide to download or to delete the email.
Now, I tried the IMAP funktion. But it seems to bee a very heavy traffic protocol.
May be, that the pmail funtion "selective download" is mutch better for my needs, because it needs far fewer traffic, since it uses the pop3 protoco l!
I'm right with my thought ???
Or does any body knows the best way to look for new email headers with slow traffic as possible?
In addion; is the a solution to download the email, but not the attachment?
Thanks for your help, and sorry for my bad english
greetings from germany, Mike
p.s.
I use pmail since the year 1992 (DOS Version)
 You are absolutely correct, POP3 using selective mail download is very much better for your needs.  That said, there is no way you can download the body text of the message without the attachment.  Even if you were to use web mail and read it on the server,  the message with all it's encoded attachments would be downloaded to your system.
        [quote user="MikeW"]<p>I use pmail to download emails via GPRS connection. Every byte of GPRS traffic is very expensive. (foreigen country)</p>
<p>So, im looking for the best solution to show the email header and than decide to download or to delete the email.
Now, I tried the IMAP funktion. But it seems to bee a very heavy traffic protocol.</p>
<p>May be, that the pmail funtion "selective download" is mutch better for my needs, because it needs far fewer traffic,&nbsp;since it uses the pop3 protoco l!
I'm right with my thought ???</p>
<p>Or does any body knows the best way to look for new email headers with slow traffic as possible?</p>
<p>In addion; is the a solution to download the email, but not the attachment?</p>
<p>Thanks for your help, and sorry for my bad english
greetings from germany, Mike</p>
<p>p.s.
</p><p>[/quote]</p><p>&nbsp;You are absolutely correct, POP3 using selective mail download is very much better for your needs.&nbsp; That said, there is no way you can download the body text of the message without the attachment.&nbsp; Even if you were to use web mail and read it on the server,&nbsp; the message with all it's encoded attachments would be downloaded to your system.&nbsp;
</p><p>
&nbsp;</p>
