I second that suggestion. It would make things much easier if the folders tree would behave like, say, the one in Windows Explorer.
Being a "keyboard user" more than a "mouse user" I have two additional wishes. Both concern quick jumps by typing a letter to select the next folder beginning with that letter.
- Allow quick jumps to folders that start with a non-US-ASCII character
- Refresh message list and preview pane to keep them in sync with the selected folder.
A note on #2:
Currently, Pegasus still displays the contents of the previously
selected folder - even when I press Tab to get to the message list
pane. Synching with a short delay to avoid drawing the list for every folder visited (like
Windows Explorer) would be perfect. Synching when I tab over to the
list pane would also be OK.
Erik
<p>I second that suggestion. It would make things much easier if the folders tree would behave like, say, the one in Windows Explorer.</p><p>Being a "keyboard user" more than a "mouse user" I have two additional wishes. Both concern quick jumps by typing a letter to select the next folder beginning with that letter.
</p><ol><li>Allow quick jumps to folders that start with a non-US-ASCII character</li><li>Refresh message list and preview pane to keep them in sync with the selected folder.</li></ol><p>A note on #2:</p><p>Currently, Pegasus still displays the contents of the previously
list pane would also be OK.</p><p>&nbsp;</p><p>Erik&nbsp;</p>
