Empfang von Mails ist problemlos möglich. Beim Senden erscheint der beschriebene Fehler.
Protokolldateien:
Versand:
--- Mon, 04 May 2009 08:49:27 ---
Connect to 'xxx.de' port 25, timeout 120.
08:49:28.633 [*] Connection established to 62.75.132.21
08:49:28.693 >> 0026 220 rack08.xxx.de ESMTP\0D\0A
08:49:28.693 << 0022 EHLO [192.168.2.100]\0D\0A
08:49:28.743 >> 0020 250-rack08.xxx.de\0D\0A
08:49:28.743 >> 0031 250-AUTH=LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.743 >> 0031 250-AUTH LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.743 >> 0014 250-STARTTLS\0D\0A
08:49:28.743 >> 0016 250-PIPELINING\0D\0A
08:49:28.743 >> 0014 250 8BITMIME\0D\0A
08:49:28.743 << 0010 STARTTLS\0D\0A
08:49:28.783 >> 0019 220 ready for tls\0D\0A
08:49:28.114 [*] SSL/TLS session established: 3DES, CBC mode, keysize 192 bits
08:49:28.114 [*] Certificate user is cn=plesk, ou=Plesk, o=SWsoft\\, Inc., l=Herndon, sp=Virginia, c=US
08:49:28.114 [*] Certificate is valid from Wed Apr 05 14:01:37 2006 to Thu Apr 05 14:01:37 2007
08:49:28.114 [*] Certificate fingerprint is AB72B40C22F74F4F0A10B05D10DA8FA2
08:49:28.124 << 0022 EHLO [192.168.2.100]\0D\0A
08:49:28.174 >> 0020 250-rack08.xxx.de\0D\0A
08:49:28.174 >> 0031 250-AUTH=LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.174 >> 0031 250-AUTH LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.174 >> 0016 250-PIPELINING\0D\0A
08:49:28.174 >> 0014 250 8BITMIME\0D\0A
08:49:28.174 << 0015 AUTH CRAM-MD5\0D\0A
08:49:28.224 >> 0050
08:49:28.224 << 0070
08:49:30.287 >> 0018 535 auth failure\0D\0A
08:49:35.154 << 0006 QUIT\0D\0A
08:49:35.204 >> 0020 221 rack08.xxx.de\0D\0A
08:49:35.204 --- Connection closed normally at Mon, 04 May 2009 08:49:35. ---\0A\0A
Empfang:
--- Mon, 04 May 2009 08:49:45 ---
Connect to 'xxx.de' port 110, timeout 120.
08:49:45.509 [*] Connection established to 127.0.0.1
08:49:46.619 >> 0018 +OK Hello there.\0D\0A
08:49:46.619 << 0006 STLS\0D\0A
08:49:46.619 >> 0027 -ERR invalid command STLS\0D\0A
08:49:46.619 << 0025 USER xxx@xxx.de\0D\0A
08:49:46.669 >> 0024 +OK Password required.\0D\0A
08:49:46.669 << 0015 PASS xxx\0D\0A
08:49:46.729 >> 0016 +OK logged in.\0D\0A
08:49:46.729 << 0006 STAT\0D\0A
08:49:46.769 >> 0009 +OK 0 0\0D\0A
08:49:46.769 << 0006 QUIT\0D\0A
08:49:46.819 >> 0014 +OK Bye-bye.\0D\0A
08:49:46.819 --- Connection closed normally at Mon, 04 May 2009 08:49:46. ---\0A\0A
pc
<p>Empfang von Mails ist problemlos möglich. Beim Senden erscheint der beschriebene Fehler.</p><p>Protokolldateien:</p><p>Versand: </p><p>--- Mon, 04 May 2009 08:49:27 ---
08:49:28.693 &gt;&gt; 0026 220 rack08.xxx.de ESMTP\0D\0A
08:49:28.693 &lt;&lt; 0022 EHLO [192.168.2.100]\0D\0A
08:49:28.743 &gt;&gt; 0020 250-rack08.xxx.de\0D\0A
08:49:28.743 &gt;&gt; 0031 250-AUTH=LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.743 &gt;&gt; 0031 250-AUTH LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.743 &gt;&gt; 0014 250-STARTTLS\0D\0A
08:49:28.743 &gt;&gt; 0016 250-PIPELINING\0D\0A
08:49:28.743 &gt;&gt; 0014 250 8BITMIME\0D\0A
08:49:28.743 &lt;&lt; 0010 STARTTLS\0D\0A
08:49:28.783 &gt;&gt; 0019 220 ready for tls\0D\0A
08:49:28.124 &lt;&lt; 0022 EHLO [192.168.2.100]\0D\0A
08:49:28.174 &gt;&gt; 0020 250-rack08.xxx.de\0D\0A
08:49:28.174 &gt;&gt; 0031 250-AUTH=LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.174 &gt;&gt; 0031 250-AUTH LOGIN CRAM-MD5 PLAIN\0D\0A
08:49:28.174 &gt;&gt; 0016 250-PIPELINING\0D\0A
08:49:28.174 &gt;&gt; 0014 250 8BITMIME\0D\0A
08:49:28.174 &lt;&lt; 0015 AUTH CRAM-MD5\0D\0A
08:49:28.224 &gt;&gt; 0050
08:49:28.224 &lt;&lt; 0070
08:49:30.287 &gt;&gt; 0018 535 auth failure\0D\0A
08:49:35.154 &lt;&lt; 0006 QUIT\0D\0A
08:49:35.204 &gt;&gt; 0020 221 rack08.xxx.de\0D\0A
&nbsp;</p><p>Empfang:</p><p>--- Mon, 04 May 2009 08:49:45 ---
08:49:46.619 &gt;&gt; 0018 +OK Hello there.\0D\0A
08:49:46.619 &lt;&lt; 0006 STLS\0D\0A
08:49:46.619 &gt;&gt; 0027 -ERR invalid command STLS\0D\0A
08:49:46.619 &lt;&lt; 0025 USER xxx@xxx.de\0D\0A
08:49:46.669 &gt;&gt; 0024 +OK Password required.\0D\0A
08:49:46.669 &lt;&lt; 0015 PASS xxx\0D\0A
08:49:46.729 &gt;&gt; 0016 +OK logged in.\0D\0A
08:49:46.729 &lt;&lt; 0006 STAT\0D\0A
08:49:46.769 &gt;&gt; 0009 +OK 0 0\0D\0A
08:49:46.769 &lt;&lt; 0006 QUIT\0D\0A
08:49:46.819 &gt;&gt; 0014 +OK Bye-bye.\0D\0A
&nbsp;</p><p>pc
