> Transend seems to have migrated my messages and folders/mailboxes in that C:/pmail/mail now contains .PMI and PMM folders. However, the
> .PMI folders have no data in them and when I bring up Pegasus, the folders/mailboxes and messages do not appear even after selecting all
> folders from the folders drop down menu. How can I make Pegasus recognize them?
When doing the migration first do a Help | About Pegasus Mail | Info in Pegasus Mail and note the HOME mail directory. Then when Transend asks for a directory specify the HOME mail directory. Make sure Pegasus Mail is not running when you do the transfer.
If the folder files (*.PMI/*.PMM) are already in the HOME mail directory then try the following procedure. This has worked for several others to restore the functionality of the message folders:
1. Use Help | About Pegasus Mail | Info to determine your mail
directory. Exit Pegasus mail.
2. Rename the file HIERARCH.PM in your HOME mail directory to
HIERARCH.SAV.
3. Run WinPMail. Your HIERARCH.PM will be re-created and should
start working correctly.
Note: This will delete any tray structure you have created and it
will have to be recreated. The process will not affect any
mail of mail folders you have, it only affects the display of
the folders.
