If the message you want to print is an html message, you can try to use Bearhtml to print it. First make sure you have Bearhtml's attention by keying in Shift + F1. If Bearhtml help appears, all is well, key in Shift + F1 again to return to the message. Now try Shift + Ctrl + P to have Bearhtml print the message.
If that does not produce the right results, you might try: Edit Bearhtml.ini to state PrintSetup=yes, save the file then restart Pegasus Mail. Re-open the message and key in Shift +_ Ctrl + P and this time a Print Setup dialog appears with a Print Propertys/Advanced button. Check the setup and advanced setup pages for alternative tray selections and set as required. Click Ok to actually print the message.
HTH
<p>Hello,</p><p>&nbsp;&nbsp;&nbsp; If the message you want to print is an html message, you can try to use Bearhtml to print it. First make sure you have Bearhtml's attention by keying in Shift + F1. If Bearhtml help appears, all is well, key in Shift + F1 again to return to the message.&nbsp; Now try Shift + Ctrl + P to have Bearhtml print the message.</p><p>If that does not produce the right results, you might try:&nbsp; Edit Bearhtml.ini to state PrintSetup=yes, save the file then restart Pegasus Mail. Re-open the message and key in Shift +_ Ctrl + P and this time a Print Setup dialog appears with a Print Propertys/Advanced button. Check the setup and advanced setup pages for alternative tray selections and set as required. Click Ok to actually print the message.
&nbsp;</p><p>HTH</p><p>&nbsp;Martin&nbsp;</p>
