Hi !
[quote user="David Harris"]
Have you perhaps attached a filtering rule set to a folder inadvertently?
Unfortunately no, I double-checked before bringing this before you guys. What is weird though is that in all the filtering (and I have a lots of them), the ones saying "Move the message to folder X" are triggered by specific criteria, but automatically all my emails are send to this folder. I do not know if I am clear, so I will take an example : assume the only rule involving folder X is "If the sender is iLike@PegasusMail.com, then move the message to folder X", then my current problem is that whatever the sender is, the message still get moved to folder X.
Have you recently changed your rule sets in any way?
I made some changes, but not to the filtering rule sets. I downloaded the great plug-in of Vincent and installed it around the 4th of August, and everything was working fine, the filtering included. Now yesterday, in the late afternoon, I updated the plug-in with the new version, and from this moment this strange moving-messages-to-folder-X pattern started. Thinking that my wimpm-32.exe was maybe corrupted, I downloaded another one from here, but it changed nothing. Then, I asked Vincent if he could send me the last version of his plug-in made just before he changed it here to deal with a DEP problem (involving the use of memory from what I understood), and he kindly put a version without the DEP fix here, which I downloaded and installed. To be really clear, here is what happened : (1) with the first version of Vincent plug-in (name it "xclose32_01", everything was working fine, (2) I used the (first) updated version of xclose32_01 which takes care of DEP problem concerning memory, so now I have on my system xclose32_02, but it did not work anymore although there was no error message of any kind, and it is after installing it that the strange filtering behavior started, (3) I asked Vincent to send me xclose32_01, but instead he modified xclose32_02 by removing the DEP fix and made the resulting version, xclose32_03, available here for all, (4) I installed xclose32_03 and it did not work either, but this time I received an error message about an initialization error (I still have to copy the error message and post it on the forum for Vincent), after which Pegasus Mail starts and the strange filtering behavior is still there. I am a bit lost by all this.
The rule processing code has been around for a long time and is pretty reliable
Of course it is ! This is one of the reason that I tried Pegasus mail in the first place. I know it is reliable for I left Pegasus Mail open for more than 4 months and it never either crashed or made a filtering error.
I suspect the problem is more likely to be a data error of some kind.
I definitely thinks that you are right, there must be some sort of corruption that has occurred somewhere, but this all thing is very strange and rather confusing. To put it in simple terms, it seems that the "New Mail Folder" is now the X folder since the former does not receive anything anymore. Maybe there is a file somewhere in the Pegasus Mail installation folder where this was mistakenly specified, and that I should change to get everything back to normal. What do you think ?
Thanks !
Ginhead.
<p>Hi !</p><p>[quote user="David Harris"]</p>Have you perhaps attached a filtering rule set to a folder inadvertently?<p>[/quote]&nbsp;</p><p>Unfortunately no, I double-checked before bringing this before you guys. What is weird though is that in all the filtering (and I have a lots of them), the ones saying "Move the message to folder X" are triggered by specific criteria, but automatically all my emails are send to this folder. I do not know if I am clear, so I will take an example : assume the only rule involving folder X is "If the sender is iLike@PegasusMail.com, then move the message to folder X", then my current problem is that whatever the sender is, the message still get moved to folder X.</p><p>[quote user="David Harris"] </p>Have you recently changed your rule sets in any way?<p>[/quote]&nbsp;</p><p>I made some changes, but not to the filtering rule sets. I downloaded the great plug-in of Vincent and installed it around the 4th of August, and everything was working fine, the filtering included. Now yesterday, in the late afternoon, I updated the plug-in with the new version, and from this moment this strange moving-messages-to-folder-X pattern started. Thinking that my wimpm-32.exe was maybe corrupted, I downloaded another one from here, but it changed nothing. Then, I asked Vincent if he could send me the last version of his plug-in made just before he changed it here to deal with a DEP problem (involving the use of memory from what I understood), and he kindly put a version without the DEP fix here, which I downloaded and installed. To be really clear, here is what happened : (1) with the first version of Vincent plug-in (name it "xclose32_01", everything was working fine, (2) I used the (first) updated version of xclose32_01 which&nbsp; takes care of DEP problem concerning memory, so now I have on my system xclose32_02, but it did not work anymore although there was no error message of any kind, and it is after installing it that the strange filtering behavior started, (3) I asked Vincent to send me xclose32_01, but instead he modified xclose32_02 by removing the DEP fix and made the resulting version, xclose32_03, available here for all, (4) I installed xclose32_03 and it did not work either, but this time I received an error message about an initialization error (I still have to copy the error message and post it on the forum for Vincent), after which Pegasus Mail starts and the strange filtering behavior is still there. I am a bit lost by all this.</p><p>[quote user="David Harris"]</p><p>The rule processing code has been around for a long time and is pretty reliable
</p><p>[/quote]&nbsp;</p><p>Of course it is ! This is one of the reason that I tried Pegasus mail in the first place. I know it is reliable for I left Pegasus Mail open for more than 4 months and it never either crashed or made a filtering error.</p><p>[quote user="David Harris"]&nbsp;</p><p>&nbsp;I suspect the problem is more likely to be a data error of some kind.</p><p>[/quote]</p><p>I definitely thinks that you are right, there must be some sort of corruption that has occurred somewhere, but this all thing is very strange and rather confusing. To put it in simple terms, it seems that the "New Mail Folder" is now the X folder since the former does not receive anything anymore. Maybe there is a file somewhere in the Pegasus Mail installation folder where this was mistakenly specified, and that I should change to get everything back to normal. What do you think ?</p><p>Thanks !</p><p>Ginhead.&nbsp;</p>
