Thanks to both of you for the responses. I have to admit that since I only use PMail on a home network, and since I'm the sole user on my computers (PC and laptop), the issue of portability and multiple access didn't occur to me; I agree that it makes the issue of multiple users' data just a *wee* bit more complicated than I'd envisioned.
Just as an aside to Martin's last comment, I don't think program code is stored in the \<user>\AppData directory, although configuration files are. Anyway, it's usable as-is even though I installed it in \Program Files; the Task Scheduler workaround seems to work fine.
The only thing left is the oddity that my center mouse button doesn't have its normal double-click functionality within PMail the way it did in XP; I suppose it's yet another "feature"... ;-)
Bob
<p>Thanks to both of you for the responses. I have to admit that since I only use PMail on a home network, and since I'm the sole user on my computers (PC and laptop), the issue of portability and multiple access didn't occur to me; I agree that it makes the issue of multiple users' data just a *wee* bit more complicated than I'd envisioned.</p><p>Just as an aside to Martin's last comment, I don't think program code is stored in the \&lt;user&gt;\AppData directory, although configuration files are. Anyway, it's usable as-is even though I installed it in \Program Files; the Task Scheduler workaround seems to work fine.</p><p>The only thing left is the oddity that my center mouse button doesn't have its normal double-click functionality within PMail the way it did in XP; I suppose it's yet another "feature"... ;-)</p><p>&nbsp;Bob
