International Pegasus Mail
Italian chellspecker
Thanks a lot Martin.
It's a shame that Pegasus doesn't  have an inline spellchecker, but a tool to check the message, as you wrote, is better than nothing.
<p>Thanks a lot Martin.</p><p>It's a shame that Pegasus doesn't  have an inline spellchecker, but a tool to check the message, as you wrote, is better than nothing. </p>
Perhaps I'm wrong, but I'm quite sure to remember there was an Italian spellchecker when I was used to use Pegasus some years ago.
Is there still something around?
<p>Perhaps I'm wrong, but I'm quite sure to remember there was an Italian spellchecker when I was used to use Pegasus some years ago.</p><p>Is there still something around? </p>
The is currently a spell checker for Italian language on this community at url:
http://community.pmail.com/files/folders/languages/entry10146.aspx
It is called TinySpell, and the dictionary file can be obtained from:
http://community.pmail.com/files/folders/languages/entry10141.aspx
One thing though. The dictionary is based on wording pre 2001 when a major change was made to Italian and German words. So this dictionary is better than nothing. There currently is no Italian dictionary support in Pegasus Mail.
<p>The is currently a spell checker for Italian language on this community at url:</p><p>http://community.pmail.com/files/folders/languages/entry10146.aspx</p><p>It is called TinySpell, and the dictionary file can be obtained from:</p><p>http://community.pmail.com/files/folders/languages/entry10141.aspx</p><p> </p><p>One thing though. The dictionary is based on wording pre 2001 when a major change was made to Italian and German words. So this dictionary is better than nothing. There currently is no Italian dictionary support in Pegasus Mail. </p><p>Martin </p>
